It is possible to delete or uncreate spotwelds.
1. | From the Menu Bar, select Connections > Spotweld > Modify. |
3. | Click to delete the selected spotwelds. |
4. | Answer the question in the pop-up dialog window with Yes or Cancel. |
Spotweld uncreation
The main advantage in uncreating spotwelds is retaining the information about the spotweld (location, set of parts) and removing the spring, its property, and the interface. By replacing one part with another, it is possible to recreate the spotwelds.
• | Click then to designate the selected spotwelds as "uncreated." |
The springs, properties, parts, and interfaces are updated and cleaned.
See also
Spotweld
Export File
