»Click here to display Table of Contents« HyperCrash > HyperCrash User's Guide > LoadCase:
If you are working in the LS-DYNA profile, from the Menu Bar, select LoadCase > Gravity Load. Right-click in the Gravity panel to access boundary conditions options. Otherwise, the following instructions will guide you in each process.
Create a gravity load
Modify or Delete a gravity load
