Parts selection
| 1. | From the Menu Bar, select Mesh Editing > Part > Duplicate. |
or
If the Mesh Editing panel is already open, select Part > Duplicate from the pull-down menu in the panel.
| 2. | Click and pick parts in the graphic window to select or unselect parts. When finished, answer the question in the Dialog menu bar with Yes or Cancel. |
or
Click
to select the parts selected in the tree.
| 3. | Select one of the duplication options: |
| • | Mesh only to duplicate only the mesh: nodes, elements, properties, materials and tree organization. |
| • | Mesh + all options to duplicate the mesh and the all features belonging to the duplicated parts. |
| 4. | Set the position of the duplicated parts with the defined displacement node moving functions: |
| 5. | Click Apply Translation to view the duplicated parts. |
| 6. | Click Save to save the part offset. |
or
Click Cancel to cancel the part offset.
| 7. | Click Close to close the menu. |
