Use the Imposed Temperature option from the LoadCase menu to create, delete, edit, or cross-reference an imposed temperature card (/IMPTEMP).
In the Imposed Temperature panel, right-click to access the context menu, and make a selection.
| Note: | Selected imposed temperature may be turned ON or OFF in the display through the Model Browser. |
All imposed temperature can be turned ON or OFF using the Display Graphic objects or Mask all graphic objects icon on the main toolbar.
| 1. | Select Create New from the context menu, then select IMPTEMP. |
The IMPTEMP card panel appears.
| 2. | Click on the arrow next to Sensor and/or Support to expand the sub-menus and make selections from these menus as applicable. |
| 3. | Click Save or Cancel when you are finished creating the card. |
