| 1. | From the Menu Bar, select LoadCase > Initial Velocity. |
| 2. | Right-click to access the context menu, then click Create New. |
| 3. | Enter a name in the Initial Velocity Creation field and validate with Ok. |
| 4. | In the Selection folder, select nodes using the different tools from the Selection folder. |
| 5. | In the Reference Axis folder: |
| • | Click the Reference Axis folder. |
| • | Define the Reference axis using the different tools from the Reference Axis folder. |
| 6. | Click to create an initial velocity in Translation. |
| 7. | Set the initial velocity components in the Vx, Vy and Vz translation component fields. |
| 8. | Click to create an initial velocity in Rotation. |
| 9. | Set the initial velocity components in the Rx, Ry and Rz rotation component fields. |
| 10. | Click Save to save the created initial velocity; or |
Click Cancel to cancel the initial velocity creation.
| 11. | Click Close to close the menu. |
Go to
Initial Velocity
