The directory of the environment files is called $MCRASHDIR. This is a variable that needs to be set in the shell environment (csh format): MCRASHDIR = <ALTAIR_HOME>/hc/environment/RADIOSS_V4/environment_kN_mm_ms_kg/ In this directory, the following files are needed:
The following variables have to be defined: $MCRASHEXE = <ALTAIR_HOME>\hc\bin\win32\mxplore $MCRASHDIR = <ALTAIR_HOME>\hc\environment\RADIOSS_V4\environment_N_mm_ms_g\ dummy_database (Example is in csh format.) |
The directory of the executable files is called $MCRASHEXE. This is a variable that needs to be set in the shell environment (csh format): MCRASHEXE = <ALTAIR_HOME>/hc/bin/<os_type>/ In this directory the following files are needed: -rwxr-xr-x MCrashV241*** lrwxr-xr-x mcrash -> MCrashV241*** An alias may be used to execute HyperCrash (csh format): alias mcrash $MCRASHEXE/mcrash |
The following types of files are necessary:
Before the Model Management menu can be used, some information needs to be set in the following files: File: $MCRASHDIR/modmng/database_main.tbl /MODMNG/DATABASE/PRIVATE <the full path private dabase 1>private_1.tbl <the full path private dabase 2>private_2.tbl ... /MODMNG/DATABASE/PUBLIC <the full path common dabase 1>database_1.tbl <the full path common dabase 2>database_2.tbl /END where:
File: <the full path database>database.tbl This file contains the models which are stored in the databases with the keyword descriptions. This file can be updated from HyperCrash. The following lines show the minimum information necessary in the database.tbl file. /MODMNG/DATABASE/DIRECTORY <the full path database> /END where:
File: $MCRASHDIR/modmng/keyword.tbl Nothing needs to be set in this file. This file is updated by HyperCrash. To learn how to add keywords, see Keyword. File: $MCRASHDIR/modmng/loadcase_main.tbl This file contains the name and the location of the loadcase files. This file needs to be created manually. Example: #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /MODNMG/LOADCASE/TYPE Front Crash $MCRASHDIR/loadcase/front_crash.tbl #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /MODNMG/LOADCASE/TYPE Rear Crash $MCRASHDIR/loadcase/rear_crash.tbl #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /MODNMG/LOADCASE/TYPE Side Crash $MCRASHDIR/loadcase/side_crash.tbl #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /END where:
File: $MCRASHDIR/loadcase/front_crash.tbl This file contains the description of the loadcase. This file needs to be created manually. Example: /MODMNG/LOADCASE/SCREEN_KEYWORD Component Model type Crash type /MODMNG/LOADCASE/MODEL Engine ENGINE FEM FRONT /MODMNG/LOADCASE/MODEL Radiator RADIATOR FEM FRONT /MODMNG/LOADCASE/MODEL Offset deformable barrier ODB FEM FRONT /END where:
Before the Dummy Management menu can be used, some information needs to be set in the following files: File: $MCRASHDIR/dummng/keyword.tbl This file needs to be created manually. Please see the Safety Module Reference Manual to learn how to set this file. Example:#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /DUMMNG/KEYWORD Norm EUROSID USSID HYBRID_I@II #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /DUMMNG/KEYWORD Percentile 5 50 95 #- #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /DUMMNG/KEYWORD Modeling RIGID FINE_MES@H COARSE_M@ESH #- #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /END File: $MCRASHDIR/dummng/database_main.tbl /MODMNG/DATABASE/PRIVATE <the full path private dabase 1>private_1.tbl <the full path private dabase 2>private_2.tbl ... /MODMNG/DATABASE/PUBLIC <the full path common dabase 1>database_1.tbl <the full path common dabase 2>database_2.tbl /END where:
File: <the full path database>database.tbl This file contains the models which are stored in the databases with the keyword descriptions. This file needs to be created manually. Default directory path definition: /MODMNG/DATABASE/DIRECTORY <the full path private database> where:
Model file definition /MODMNG/DATABASE/MODEL <the full path of the model>/model_file_name where:
End of the file /END where:
