You may choose to delete one or more parts or assemblies from your model. You can select parts and assemblies to delete at the same time if you wish.
1. | In the Tree window, select parts and/or assemblies to be deleted. |
Several parts/assemblies can be selected using the SHIFT, CTRL, or SHIFT+CTRL keys.
2. | Right-click the mouse button to access the context menu. |
3. | Select Delete. |
4. | Answer the question in the pop-up dialog. |
All the features (interfaces, added masses, initial velocities, etc.) associated with the deleted parts and/or assemblies are automatically updated.
