Creates a straight line.
line = NEW_LINE(
node1, node2
line
The line.
node1
The first node defining the line.
node2
The second node defining the line.
line = NEW_LINE( node, vector ) ;
line
The line.
node
A node contained by the line.
vector
The vector tangent to the line.
line = NEW_LINE( x1, y1, z1, x2, y2, z2 ) ;
line
The line.
x1
The coordinate of the first node.
y1
z1
x2
The coordinate of the second node.
y2
z2
The coordinates supplied in the third syntax must be real numbers (at least a period or an exponent is necessary).
