In the selection by BOX GROUP sub-window:
| 1. | Select one or several box(es) in the list and click to view the box(es). |
| 2. | Click to create a new box. |
A Group by Box window appears:
| 3. | Enter the group name in the Group name window. |
| 4. | In the Original Position: |
| • | Click and pick a node in the graphic window. |
or
Enter X, Y, and Z coordinates.
| • | Click Ok to validate the point definition. |
| 5. | In the Ending Position: |
or
| 6. | In the Dimensions portion, modify the size of the box: |
| • | Use to change the size of the box for each direction. |
or
Enter the size of the box in the dimensions windows.
| • | Click Ok to validate the modified box size. |
| 7. | Click to update the box display. |
| 8. | Click Save to save the box creation; or |
Click Cancel to cancel the box creation.
| 9. | Click Close to close the box creation window. |
Box modification
| 1. | Select only one box in the list window. |
| 2. | In the pop-up menu (right button of the mouse) select the function, Modify. |
In the box creation window that appears:
| 4. | Click to update the box display. |
| 5. | Click Save to save the box creation; or |
| 6. | Click Close to close the box creation window. |
Box deletion
| 1. | Select a box in the list window (using the SHIFT and CTRL keys). |
or
Click
to select all listed boxes.
| 2. | Click to delete the selected boundary conditions. |
or
In the pop-up menu (right button of the mouse) select the function, Delete.
| 3. | Answer the question in the Dialog menu bar with Yes or Cancel. |
Go to
Global: Group Selection
