The file, $MCRASHDIR/bolt/boltdef defines the bolt creation default values.
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Version_number |
Where: |
Type |
Unit |
is the file identifier |
Text |
No |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Bolt_name |
Where: |
Type |
Unit |
Is the default bolt name |
Text |
No |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Property_name |
Where: |
Type |
Unit |
is the default spring property file name |
Text |
No |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Length1 |
Length2 |
Diameter1 |
Where: |
Type |
Unit |
is the first cylinder’s length |
Real |
Length |
is the second cylinder’s length |
Real |
Length |
is the cylinder’s diameter |
Real |
Length |
1 |
2 |
3 |
4 |
5 |
6 |
7 |
8 |
9 |
10 |
Spring_length |
Where: |
Type |
Unit |
is the length of the spring set in the bolt with spring. |
Real |
Length |
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| # BOLT DEFINITION FILE #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---|
# UNIT : s, N , mm, T (1t=1000kg)
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| # 1. GLOBAL DEFINITIONS: #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| #version number V3.13_2.0 #default bolt name New_Bolt #default property name SPRI_13_Bolt #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| # length1| length2| diameter1| 10. 10. 20. # spring length|(1 mm) 1. #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| # END OF BOLT DEFINITION FILE #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| |
