The material files are located in the directory, $MCRASHDIR/mat. There is one material per file. The file is written with the RADIOSS format (V41, V42 or V44).
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /MAT/LAW2/01/STEEL #Initial density .790000000E-08 # E nu 210000.000 .300000000 # a b n epsilon max maximum stress 200.000000 450.00000 .500000000 .100000000E+31 425.00000 # c ref strain rate ICC .000000000 .000000000 0 # m Tmelt Specific Heat Initial temp 0 0 0 0 /END #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| |
The property files are located in the directory, $MCRASHDIR/property. There is one property per file. The file is written with the RADIOSS format (V41, V42 or V44).
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /PROP/TYPE13/1/SPRI_13_Welding 2.00000000E-06 2.00000000E-04 1 0 0 0 100000. .000000000 .000000000 .000000000 .000000000 1 0 0 0 .000000000 .000000000 100000. .000000000 .000000000 .000000000 .000000000 2 0 0 0 .000000000 .000000000 100000. .000000000 .000000000 .000000000 .000000000 3 0 0 0 .000000000 .000000000 1000000 .000000000 .000000000 .000000000 .000000000 0 0 0 0 .000000000 .000000000 1000000 .000000000 .000000000 .000000000 .000000000 0 0 0 0 .000000000 .000000000 1000000 .000000000 .000000000 .000000000 .000000000 0 0 0 0 .000000000 .000000000 #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /CURVE/1/curve 1 -0.10000000 -0.10000000 .000000000 .000000000 .100000000 .100000000 .200000000 .200000000 .300000000 30.0000000 /CURVE/2/curve 2 -0.10000000 -0.10000000 .000000000 .000000000 .100000000 .100000000 .200000000 .200000000 .300000000 30.0000000 /CURVE/3/curve 3 -0.10000000 -0.10000000 .000000000 .000000000 .100000000 .100000000 .200000000 .200000000 .300000000 30.0000000 /SKEW/MOV/1/Skew 1 1 2 3 /END #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---|
The skew files are defined in the directory, $MCRASHDIR/skew. The file contains the fix skew frame card in RADIOSS 4.1 Block Format.
The line, /END is added to close the file reading.
#--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| /SKEW/FIX/1/-X-YZ 0 -1 0 0 0 1 /END #--1---|---2---|---3---|---4---|---5---|---6---|---7---|---8---|---9---|--10---| |
