1. | Select Nodes for Select by. |
2. | Click the Select radio button and select the fixed nodes using the following tools: |
• | Click and pick nodes in the graphic window. |
• | Click to add nodes by box selection. |
• | Click to remove nodes by box selection. |
• | Click to select all nodes of the previous seat cushion selection. |
3. | Select Part for Select by. |
4. | Select the parts of the dummy using the following tools: |
• | Click and pick parts in the graphic window. |
• | Click to add parts by box selection. |
• | Click to remove parts by box selection. |
• | Click to add the parts selected in the tree. |
• | Click to remove the parts selected in the tree. |
5. | Click Accept to validate the selection. |
