| Note: | Only free nodes (nodes connected to nothing) can be deleted. Press the F8 key to display the free nodes. |
| 1. | From the Menu Bar, select Mesh Editing > Node > Modify. |
or
If the Mesh Editing panel is already open, select Node > Modify from the pull-down menu in the panel.
| 2. | Select the Delete radio button in the panel. |
To delete the free nodes one-by-one:
| 1. | Click . |
| 2. | In the graphic window, click a free node (white node) to delete it. |
The node is highlighted in red.
| 3. | To confirm, click Save to delete the nodes; or |
To cancel, click Cancel.
| 4. | Click Close to close the menu. |
To delete all the free nodes:
| 1. | Click . |
| 2. | Answer the question in the pop-up dialog window with Yes or Cancel. |
| 3. | Click Close to close the menu. |
