| 1. | From the Menu Bar, select Mass > Rigid Bodies Details. |
There are three sub-tabs, displaying:
| • | the Mass of the rigid bodies |
| • | the COG (center Of Gravity) of the rigid bodies |
| • | the Inertia of the rigid bodies |
| 2. | Select rigid bodies by picking the rigid bodies line directly in the listing window. Several rigid bodies of this list can be selected using the SHIFT, CTRL, or SHIFT+CTRL keys. |
or
| • | Click to select all the subparts, parts and assemblies of the model. |
or
| • | Click to select all the parts of the rigid body of the model. |
or
| • | Click to select all the rigid bodies of the model. |
| 3. | Click to print the selected rigid bodies' information from the active sub-tabs to a text file. |
| • | Enter the name of the file in the Selection field. |
| • | Click OK to save the file. |
| • | Click Cancel to cancel this function. |
| 4. | Click to print the selected rigid bodies' information from all three sub-tabs to a text file. |
| 5. | Click Close to close this window. |
See also
Part Mass Details
Balancing
