| • | From the Menu Bar, select Mesh Editing > Node > Modify. |
or
| • | If the Mesh Editing panel is already open, select Node > Modify from the pull-down menu in the panel. |
| 1. | Select the Merge single radio button. |
| 2. | Click |
| 3. | In the graphic window, click the first node, and then click the second node. |
The first node will move and will merge with the second one. The second node does not move.
| 4. | Click Save to merge the nodes; or |
To cancel node merging, click Cancel.
| 5. | Click Close to close the menu. |
| 1. | Select the Merge multi radio button. |
| 2. | Click the Set 1 radio button to activate it. |
Button |
Behavior |
pick nodes in the graphic window, and then press Enter, right-click the mouse button or select Yes or Cancel in the Dialog menu bar. |
add nodes by box selection (the default box is rectangular — use the SHIFT key to define a polygon box). |
remove nodes by box selection (the default box is rectangular — use the SHIFT key to define a polygon box). |
pick parts in the graphic window, and then press Enter, right-click the mouse button or select Yes or Cancel in the Dialog menu bar. |
add parts by box selection (the default box is rectangular — use the SHIFT key to define a polygon box). |
remove parts by box selection (the default box is rectangular — use the SHIFT key to define a polygon box). |
add the parts selected in the tree. |
remove the parts selected in the tree. |
| 4. | Click the Set 2 radio button to activate it. |
| 5. | Select the nodes for the second set (same procedure as selecting nodes for the first set). |
| 6. | In the gap search to merge field, enter the tolerance to search the possible nodes to merge. |
| 7. | Click |
The nodes of the first set will move and will be merged with the nodes of the second set. The nodes of the second set do not move.
| 8. | Click Save to merge the nodes; or |
Click Cancel to cancel node merging.
| 9. | Click Close to close the menu. |
