HyperCrash
To modify a Variable or a Response
1.Go to the Variables or Responses notebook page.
modify_var-10
2.Select an object from the list of defined variables.
3.Click the reviewGeneral-24 button.
4.Edit the available field(s) in the lower window when you created the variable or response.
Go to
Stochastic Analysis
Optimization Study
