*MAT_240 (COHESIVE_MIXED_MODE_ELASTOPLASTIC_RATE)
LS-DYNA Input Interface KeywordThis keyword defines a perfectly plastic cohesive material with state dependency, normal and shear damage, and normal and shear failure.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*MAT_240 or *MAT_COHESIVE_MIXED_MODE_ELASTOPLASTIC_RATE | |||||||
mat_ID | En | Gs | Thick | ||||
En_0 | En_1 | En_rate | n_0 | n_1 | N_rate | Form_n | |
Es_0 | Es_1 | Es_rate | s_0 | s_1 | S_rate | Form_s |
Definition
mat_ID | Material identifier (Integer) |
Initial density (Real) |
En | Young’s modulus in the normal direction (Real) |
Gs | Shear modulus in the shear plane (Real) |
Thick | Reference cohesive thickness (Real) |
En_0 | Energy for damage and failure in the normal direction
(Real) |
En_1 | Upper energy value for damage and failure in the normal
direction (used only is En_0 <
0). (Real) |
En_rate | Plastic strain rate factor for damage and failure in the
normal direction (used only is En_0 <
0). (Real) |
n_0 | Yield stress in normal direction
(Real) |
n_1 | Yield stress factor in the normal direction (used only is
< 0). (Real) |
N_rate | Plastic strain rate factor for yield stress in the normal
direction (used only is < 0). (Real) |
Form_n | Tri-linear shape formulation in the normal direction
(Real) |
Es_0 | Energy for damage and failure in the shear plane
(Real) |
Es_1 | Upper energy value for damage and failure in shear plane
(used only is Es_0 <
0). (Real) |
Es_rate | Plastic strain rate factor for damage and failure in shear
plane (used only is Es_0 <
0). (Real) |
s_0 | Yield stress in the shear plane
(Real) |
s_1 | Yield stress factor in the shear plane (used only is <
0). (Real) |
S_rate | Plastic strain rate factor for yield stress in the shear
0). (Real) |
Form_s | Tri-linear shape formulation in the shear plane
(Real) |
- This keyword maps to /MAT/LAW83, /PROP/TYPE43 (CONNECT), and /FAIL/SNCONNECT.
- Yield stress when rate dependency is defined with:
- If > 0:
- If < 0:
- If > 0:
- If < 0:
- Energy for damage and failure dependency is defined with:
- The tri-linear fracture model is defined with:
Figure 1.- If Form > 0,
- with = total energy, = perfect plastic energy in normal direction
- with = total energy, = perfect plastic energy in shear plane
- If Form < 0,
- with = displacement in normal direction
- with = displacement in shear plane
- If Form > 0,
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 character long line is added after the keyword input line which allows an entity title to be defined.
