*SET_PART_ADD
LS-DYNA Input Interface KeywordThis keyword defines a set of parts from a list of existing part sets.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *SET_PART_ADD | |||||||
| set_ID | |||||||
| set_ID1 | set_ID2 | set_ID3 | set_ID4 | set_ID5 | set_ID6 | set_ID7 | set_ID8 |
Definition
| set_ID | Part set identifier (Integer) |
| set_ID1 - set_ID8 | Part Set IDs, 8 per line (Integer) If a set_ID(n) is negative, all the sets in the range, set_ID(n-1) through |set_ID(n)| are included in the set. |
- This keyword maps to /SET/GENERAL.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 character long line is added after the keyword input line which allows an entity title to be defined.
