*LOAD_NODE
LS-DYNA Input Interface KeywordDefines a concentrated force or moment applied on a defined node or to each node of a nodal set.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*LOAD_NODE_OPTION |
node_ID | DOF | fct_IDT | Fscaley | CID |
set_ID | DOF | fct_IDT | Fscaley | CID |
Definition
node_ID | Node identifier (Integer) |
set_ID | Node set identifier (Integer) |
DOF | Load direction
(Integer) |
fct_IDT | Function identifier (Integer) |
Fscaley | Ordinate scale factor Default = 1.0 (Real) |
CID | Coordinate system identifier (Integer) |
