*DATABASE_HISTORY_NODE
LS-DYNA Input Interface KeywordDefines a list of nodes for output in time history file.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*DATABASE_HISTORY_NODE_{OPTION} | |||||||
ID1 | ID2 | ID3 | ID4 | ID5 | ID6 | ID7 | ID8 |
Etc. |
If OPTION = LOCAL, insert the following lines.
ID1 | CID | REF | |||||
ID2 | CID | REF | |||||
Etc. |
Definition
OPTION |
ID | Node identifier (Integer) |
CID | Local coordinate system identifier used for
output (Integer) |
REF |
(Integer) |
- This keyword maps to /TH/NODE.
- A moving coordinate system based on nodes is used when REF=1.
