*CONSTRAINED_RIGID_BODIES
LS-DYNA Input Interface KeywordDefine rigid bodies assembly.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*CONSTRAINED_RIGID_BODIES | |||||||
Part_M_ID | Part_S_ID | Iflag |
Definition
Part_M_ID | Part identifier with main rigid
material. (Integer) |
Part_S_ID | Part identifier with secondary rigid
Iflag | Flag for merged rigid body property (used if
Part_M_ID is
PART_INERTIA)
(Integer) |
- This keyword maps to /MERGE/RBODY.
