*AIRBAG_SIMPLE_AIRBAG_MODEL
LS-DYNA Input Interface KeywordThis model defines a one-chambered airbag with uniform pressure method, injected gas and vent hole.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*AIRBAG_SIMPLE_AIRBAG_MODEL_{OPTION} |
monvol_ID | Title |
surf_IDex | Surf_typ | ||||||
CV | CP | T | Fct_IDM | MU | AREA | Pext | |
Text | Cpa | Cpb | MW |
Definition
monvol_ID | Airbag Identifier (Integer) |
Title | Title (character) |
surf_IDex | Airbag external surface identifier (Integer) |
Surf_typ | Set type
(Integer) |
CV | Heat capacity at constant volume. 2 (Real) |
CP | Heat capacity at constant pressure (Real) |
T | Input gas temperature (Real) |
Fct_IDM | Mass flow rate of injected gas vs. time function
identifier. (Integer) |
MU | Vent hole shape
Default = 1 (Real) |
Area | Vent hole area
(Real) |
Pext | External pressure (Real) |
Text | External temperature Default = 295 K (Real) |
Cpa | First heat capacity coefficient of injected
gas (Real) |
Cpb | First heat capacity coefficient of injected
gas (Real) |
MW | Molecular weight of gas (Real > 0) |
- This keyword maps to /MONVOL/AIRBAG1, /MAT/GAS, and /PROP/INJECT1.
- If
CV = 0, specific heat parameters are
computed as:
