*ELEMENT_SHELL
LS-DYNA Input Interface KeywordDefines a shell element with 3 or 4 nodes.
(1) (2) (3) (4) (5) (6) (7) (8)
*ELEMENT_SHELL_{OPTION}
EID part_ID N1 N2 N3 N4
If OPTION = THICKNESS, insert the following line.
T1 T2 T3 T4
Definition
OPTION
THICKNESS
Optional flag to input the thickness at each node.
EID Element identifier.
(Integer)
part_ID Part identifier.
(Integer)
N1, N2, N3, N4 Node ID.
(Integer)
T1, T2, T3, T4 Optional thickness at each node. Only used when OPTION=THICKNESS.
(Real)
  1. This keyword maps to /SHELL, if 4 nodes are entered and /SH3N, if 3 nodes are entered.
  2. When the node thickness is entered, an average element thickness is used in the calculation.
