*ELEMENT_BEAM
LS-DYNA Input Interface KeywordDefines a beam, discrete beam, or a truss element.
(1) (2) (3) (4) (5) (6) (7) (8)
*ELEMENT_BEAM_{OPTION}
EID part_ID N1 N2 N3
If OPTION = ORIENTATION, insert the following line
VX VY VZ
Definition
OPTION
ORIENTATION
Optional flag to define the orientation of the beam element.
EID Element identifier.
(Integer)
part_ID Part identifier.
(Integer)
N1, N2, N3 Node identifier.
(Integer)
VX, VY, VZ Vector to define cross section orientation. When used the input for N3 is ignored.
(Real)
  1. This keyword maps to a /BEAM, /SPRING or /TRUSS element depending on the ELFORM value in *SECTION_BEAM.
