*MAT_S08 (SPRING_INELASTIC)
LS-DYNA Input Interface KeywordThis keyword defines a nonlinear spring material with stiffness available only in tension or in compression.
(1) (2) (3) (4) (5) (6) (7) (8)
*MAT_S08 or *MAT_SPRING_INELASTIC
mat_ID LCFD   CTF
Definition
mat_ID Material identifier
(Integer)
LCFD Loading curve identifier: force vs displacement or moment vs rotation angle. The curve should start with (0, 0) and be defined in first quadrant only.
(Integer)
CTF
= -1.0
Tension only spring
= 1.0 (Default)
Compression only spring
(Integer)
  1. This keyword maps to /PROP/TYPE8 (SPR_GENE) spring using a default mass 2.0e-03 kg and inertia 2e-02 kg*mm depending on the units.
  2. The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 character long line is added after the keyword input line which allows an entity title to be defined.
