LS-DYNA Input Interface KeywordThis model expresses a one-chambered airbag with pressure as a function of
volume.
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
| *AIRBAG_SIMPLE_ PRESSURE_VOLUME
_{OPTION} |
If
OPTION =
ID, insert the following
line.
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
| ID |
Title |
| (1) |
(2) |
(3) |
(4) |
(5) |
(6) |
(7) |
(8) |
| surf_IDex |
Surf_typ |
| CN |
BETA |
Definition
| Field |
Contents |
SI Unit Example |
| ID |
Airbag Identifier (Integer)
| Title |
Title (Character)
| surf_IDex |
Airbag external surface identifier (Integer)
| Surf_typ |
Set type
- 0
- Set of parts
| CN |
Pressure coefficient
- > 0
(Real)
| BETA |
Pressure scale factor (Real)
- This keyword maps to /MONVOL/PRES.
- Relative volume is defined as:(1)
