*MAT_081 (PLASTICITY_WITH_DAMAGE)
LS-DYNA Input Interface KeywordThis keyword defines an isotropic elasto-plastic material using tabulated stress vs plastic strain input for different strain rates and simple damage model.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*MAT_081 or *MAT_PLASTICITY_WITH_DAMAGE | |||||||
mat_ID | E | ν | SIGY | ETAN | FAIL | ||
C | P | LCSS | LCSR | EPS_max | VP | Numint | |
EPS1 | EPS2 | EPS3 | EPS4 | EPS5 | EPS6 | EPS7 | EPS8 |
ES1 | ES2 | ES3 | ES4 | ES5 | ES6 | ES7 | ES8 |
Definition
mat_ID | Material Identifier (Integer) |
Initial density (Real) |
E | Young’s modulus (Real) |
v | Poisson’s ratio Default = 0 (Real) |
SIGY | Yield stress, ignored if LCSS >
0 or stress-strain values
EPS1-EPS8,
ES1-ES8
specified (Real) |
ETAN | Plastic hardening modulus, not used if
LCSS >
0 (Real) |
FAIL | Plastic strain for material softening (Real) |
C | Strain rate coefficient (Real) |
P | Strain rate exponent (Real) |
LCSS | Stress vs plastic strain curve or table
identifier (Integer) |
LCSR | Curve identifier defining the scaling coefficient for the
stress-strain curve for a corresponding strain
rate (Integer) |
EPS_max | Plastic strain for element deletion (Real) |
VP | Strain rate type flag:
(Integer) |
EPS1-EPS8 | Plastic strain data points (Real) |
ES1-ES8 | Yield stress data points (Real) |
- This keyword maps to /MAT/LAW36 (PLAS_TAB) or /MAT/LAW44 (COWPER) according to the input.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 character long line is added after the keyword input line which allows an entity title to be defined.
