*MAT_018 (POWER_LAW_PLASTICITY)
LS-DYNA Input Interface KeywordThis model expresses isotropic plasticity model with rate effects which uses a power law hardening.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*MAT_018 or *MAT_POWER_LAW_PLASTICITY | |||||||
mat_ID | E | v | K | N | c | p | |
SIGY | VP |
Definition
mat_ID | Material identifier (Integer) |
Initial density (Real) |
E | Young’s modulus (Real) |
v | Poisson’s ratio (Real) |
K | Yield stress (Real) |
N | Plasticity hardening exponent Default = 1.0 (Real) |
c | Strain rate coefficient
(Real) |
p | Strain rate exponent Default = 1.0 (Real) |
SIGY | Optional yield stress value (Real) |
VP | Formulation for rate effects:
(Integer) |
Plasticity maximum stress Default = 1030 (Real) |
- This keyword maps to /MAT/LAW44 (COWPER) + /FAIL/JOHNSON.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 character long line is added after the keyword input line which allows an entity title to be defined.
