*CONTACT_AUTOMATIC_NODES_TO_SURFACE
LS-DYNA Input Interface KeywordDefine nodes to surface contact interface.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*CONTACT_AUTOMATIC_NODES_TO_SURFACE _{OPTION3} |
inter_ID | Title |
SSID | MSID | SSTYP | MSTYP | ||||
FS | FD | DC | Tstart | Tstop | |||
SFS | SFM | SST | MST | SFTS | SFMT | FSF |
Definition
OPTION3 | ID Include a contact identifier and title |
inter_ID | Contact interface identifier (Integer) |
Title | Contact interface title (Character, maximum 70 characters) |
SSID | Secondary set or part identifier (Integer) |
MSID | Main set or part identifier (Integer) |
SSTYP | Input secondary set type
(Integer) |
MSTYP | Input main set type
(Integer) |
FS | Static friction coefficient (Real) |
FD | Dynamic friction coefficient (Real) |
DC | Exponential decay coefficient | |
Tstart | Start time (Real) |
Tstop | Stop time Default = 1E+30 (Real) |
SFS | Secondary stiffness scale factor (Real) |
SFM | Main stiffness scale factor (Real) |
SST | Secondary maximum gap value (Real) |
MST | Main maximum gap value (Real) |
SFTS | Secondary contact gap scale (Real) |
SFMT | Main contact gap scale (Real) |
FSF | Coulomb friction coefficient scale factor |
- This keyword maps to /INTER/TYPE25.
