*RIGIDWALL_GEOMETRIC
LS-DYNA Input Interface KeywordDefine a rigid wall with the different following shape.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *RIGIDWALL_GEOMETRIC_TYPE_{OPTION}_{OPTION}_{OPTION} | |||||||
| Rwall_ID | Title | ||||||
| Set_ID | Setex_ID | Box_ID | |||||
| XT | YT | ZT | XH | YH | ZH | FRIC |
| Radius |
| XHEV | YHEV | ZHEV | LENL | LENM |
| XHEV | YHEV | ZHEV | LENL | LENM | LENP |
| Fct_ID | OPT | VX | VY | VZ |
Definition
| TYPE |
| OPTION |
| Rwall_ID | Optional rigid wall identifier (Integer) |
| Title | Optional title (Character, maximum 70 characters) |
| Set_ID | Node set for the rigid wall contact (Integer) |
| Setex_ID | Node set to exclude from the rigid wall
contact (Integer) |
| Box_ID | Box identifier for the rigid wall
contact (Integer) |
| XT | Rigid wall tail point X coordinate (Real) |
| YT | Rigid wall tail point Y coordinate (Real) |
| ZT | Rigid wall tail point Z coordinate (Real) |
| XH | Rigid wall head point X coordinate (defining normal
direction) (Real) |
| YH | Rigid wall head point Y coordinate (defining normal
direction) (Real) |
| ZH | Rigid wall head point Z coordinate (defining normal
direction) (Real) |
| FRIC | Coulomb friction coefficient (Real) |
| Radius | Cylinder or sphere radius (Real) |
| XHEV | Rigid wall edge point X coordinate (Real) |
| YHEV | Rigid wall edge point Y coordinate (Real) |
| ZHEV | Rigid wall edge point Z coordinate (Real) |
| LENL | Rigid wall size on the 1st edge (Real) |
| LENM | Rigid wall size on the 2nd edge (Real) |
| LENP | Rigid wall size on the 3rd edge (in opposite as normal
direction) (Real) |
| Fct_ID | Imposed motion function (velocity/displacement versus
time) (Integer) |
or |
| OPT | Imposed motion type
| VX | Imposed motion direction X (Real) |
| VY | Imposed motion direction Y (Real) |
| VZ | Imposed motion direction Z (Real) |
