*MAT_S02 (DAMPER_VISCOUS)
LS-DYNA Input Interface KeywordThis keyword defines a linear damper spring material.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_S02 or *MAT_DAMPER_VISCOUS | |||||||
| mat_ID | D | ||||||
Definition
| mat_ID | Material identifier (Integer) |
| D | Linear or rotational damping (Real) |
or |
- This keyword maps to /PROP/TYPE8 (SPR_GENE) spring using a default mass 2.0e-03 kg and inertia (2e-02 kg * mm depending on the units).
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 character long line is added after the keyword input line which allows an entity title to be defined.
