*CONSTRAINED_ SPOTWELD
LS-DYNA Input Interface KeywordDefine a connection between 2 nodes with a possible force based failure model.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*CONSTRAINED_SPOTWELD_{OPTION} |
ID |
node_ID1 | node_ID2 | SN | SS | N | M |
Definition
ID | Weld identifier (Integer) |
node_ID1 | Node identifier 1 (Integer) |
node_ID2 | Node identifier 2 (Integer) |
SN | Normal tensile force at failure
(Real) |
SS | Normal shear force at failure
(Real) |
N | Exponent for the normal force (Real) |
M | Exponent for the shear force (Real) |
- This keyword maps to spring element (/SPRING) and property (/PROP/TYPE25 (SPR_AXI)) and (SENSOR/TIME).
- The failure is defined with the following expression:
(1)
