*SET_NODE_ADD
LS-DYNA Input Interface KeywordThis keyword defines a set of nodes from a list of existing sets.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*SET_NODE_ADD_{OPTION} | |||||||
set_ID |
If OPTION = <BLANK>, repeat the following line as needed.
set_ID1 | set_ID2 | set_ID3 | set_ID4 | set_ID5 | set_ID6 | set_ID7 | set_ID8 |
If OPTION = ADVANCED, repeat the following line as needed.
set_ID1 | Type_1 | set_ID2 | Type_2 | set_ID3 | Type_3 | set_ID4 | Type_4 |
Definition
OPTION | Type of set to combine
set_ID | Node set identifier (Integer) |
set_ID1 - set_ID8 | Node Set IDs, 8 per line (Integer) |
set_ID1 - set_ID4 | Set IDs (Integer) |
Type_1 - Type_4 | Set type
(Integer) |
- This keyword maps to /SET/GENERAL.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 character long line is added after the keyword input line which allows an entity title to be defined.
