*CONTACT_SPOTWELD
LS-DYNA Input Interface KeywordDefine nodes to surface contact interface dedicated for spotweld connection.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*CONTACT_SPOTWELD_{OPTION3} |
inter_ID | Title |
SSID | MSID | SSTYP | MSTYP | ||||
Blank card | |||||||
Blank card |
Definition
OPTION3 | ID Include a contact identifier and title |
inter_ID | Contact interface identifier (Integer) |
Title | Contact interface title (Character, maximum 70 characters) |
SSID | Secondary set or part identifier (Integer) |
MSID | Main set or part identifier (Integer) |
SSTYP | Input secondary set type
(Integer) |
MSTYP | Input main set type
(Integer) |
- This keyword maps to /INTER/TYPE2.
- The secondary node remains at its original position.
