*SET_SOLID
LS-DYNA Input Interface KeywordThis keyword defines a set of solids based on a list of solids in various ways.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *SET_SOLID_{OPTION} | |||||||
| set_ID | |||||||
| E_ID1 | E_ID2 | E_ID3 | E_ID4 | E_ID5 | E_ID6 | E_ID7 | E_ID8 |
| TYPE | ID1 | ID2 | ID3 | ID4 | ID5 | ID6 | ID7 |
| ID8 | ID9 | ID10 | ID11 | ID12 | etc |
Definition
| OPTION |
| set_ID | Element set identifier (Integer) |
| E_ID1- E_ID10 | Element IDs, 8 per line (Integer) |
| TYPE |
| ID1, ID2, ID3 .. | Entity IDs, 7 per line (Integer) |
- This keyword maps to /SET/GENERAL.
- The adding and removing of elements in *SET_SOLID_GENERAL depends on the order of the TYPE options used.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 character long line is added after the keyword input line which allows an entity title to be defined.
