*SECTION_SOLID
LS-DYNA Input Interface KeywordThis keyword defines the finite element properties of solid elements.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *SECTION_SOLID | |||||||
| sec_ID | ELFORM | ||||||
Definition
| sec_ID | Section identifier (Integer) |
| ELFORM | Solid element formulation options.
(Integer) |
- This keyword maps to /PROP/TYPE14 (SOLID) for an isotropic material and /PROP/TYPE6 (SOL_ORTH) for an orthotropic material. For connection elements ELFORM = 19 or 20, this keyword maps to /PROP/TYPE43 (CONNECT).
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 character long line is added after the keyword input line which allows an entity title to be defined.
