*ELEMENT_SEATBELT_ACCELEROMETER
LS-DYNA Input Interface KeywordThis keyword defines an accelerometer.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*ELEMENT_SEATBELT_ACCELEROMETER | |||||||
ELE_ID | node_ID1 | node_ID2 | node_ID3 | Mass |
Definition
ELE_ID | Accelerometer ID (Integer) |
node_ID1 | First node ID to defined local coordinate system
(base) (Integer) |
node_ID2 | Second node ID to defined local coordinate system (local
direction X) (Integer) |
node_ID3 | Third node ID to defined local coordinate system (local plane
XY) (Integer) |
Mass | Accelerometer mass (Real) |
