*DEFINE_COORDINATE_SYSTEM
LS-DYNA Input Interface KeywordThis keyword defines a fixed coordinate system.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*DEFINE_COORDINATE_SYSTEM | |||||||
CID | X0 | Y0 | Z0 | X1 | Y1 | Z1 | |
XP | YP | ZP |
Definition
CID | Coordinate system identifier (Integer) |
X0, Y0, Z0 | Coordinates of system origin (Real) |
X1, X2, X3 | Coordinates of the point determining the X axis
(Real) |
XP, YP, ZP | Coordinates of the point determining the XY
plane (Real) |
- This keyword maps to /SKEW/FIX.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 character long line is added after the keyword input line which allows an entity title to be defined.
