*MAT_027 (MOONEY-RIVLIN_RUBBER)
LS-DYNA Input Interface KeywordDefines a Mooney-Rivlin isotropic hyperelastic incompressible material.
(1) (2) (3) (4) (5) (6) (7) (8)
*MAT_027 or *MAT_MOONEY-RIVLIN_RUBBER
mat_ID ρ i υ A B
Length Width Thickness LCID
Definition
mat_ID Material identifier.
(Integer)
ρ i Initial density.
(Real)
[ kg m 3 ]
A, B Mooney-Rivlin Material constants.
(Real)
υ Poisson’s ratio.
(Real)
[ Pa ]
Length Sample length.
(Real)
[ m ]
Width Sample width.
(Real)
[ m ]
Thickness Sample thickness.
(Real)
[ m ]
LCID Function identifier of Force vs elongation.
(Integer)
[ N ]
  1. This maps to /MAT/LAW69, if LCID is defined otherwise it maps to /MAT/LAW42 (OGDEN).
  2. The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 character long line is added after the keyword input line which allows an entity title to be defined.
