*DATABASE_CROSS_SECTION_SET
LS-DYNA Input Interface KeywordDefine a cross section to output the force and moment defined by a group of nodes and groups of elements.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *DATABASE_CROSS_SECTION_SET_{OPTION2} | |||||||
| CSID | Title | ||||||
| NSID | HSID | BSID | SSID | TSID | DSID |
Definition
| CSID | Cross plane section identifier (Integer) |
| Title | Contact interface title (Character, maximum 70 characters) |
| NSID | Node set identifier (Integer) |
| HSID | Solid set identifier (Integer) |
| BSID | Beam set identifier (Integer) |
| SSID | Shell set identifier (Integer) |
| TSID | Thickshell set identifier (Integer) |
| DSID | Discrete set identifier (Integer) |
- This keyword maps to /SECT and /TH/SECTIO.
