*LOAD_BODY
LS-DYNA Input Interface KeywordDefines an acceleration load.
(1) (2) (3) (4) (5) (6) (7) (8)
*LOAD_BODY_{OPTION}
LCID SF         CID
Definition
OPTION Direction of the acceleration load. The force from the acceleration is applied in the opposite direction.
X, Y, Z
LCID Curve identifier for gravity acceleration load as function of time.
(Integer)
SF Scaling coefficient applied to the ordinate of the gravity curve.
Default = 1.0 (Real)
CID Coordinate system identifier.
(Integer)
  1. This keyword maps to /GRAV.
