Single File Input
Filename convention is ROOTNAME_0000.rad.
The file must start with:
#(blank) RADIOSS
The Engine options in the single file must be:
  • Placed in the beginning of the single file
  • Finish with /END/ENGINE
The Starter options must:
  • Start with /BEGIN
  • Finish with /END
Syntax has to be written as:
#(blank) RADIOSS
Engine options
/END/ENGINE
/BEGIN
	Starter options
/END
  1. Engine options must be in the main file, #include is not supported in the Engine file.
  2. In case of restart, it is sufficient to regenerate the Engine file alone.
  3. Multiple Engine instances are not supported in the Single File Input.
