*MAT_100 (SPOTWELD)
LS-DYNA Input Interface KeywordThis keyword defines an elasto-plastic spotweld material for beam element (elform=9) or solid element.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *MAT_100 or *MAT_SPOTWELD | |||||||
| mat_ID | E | ν | SIGY | ET | |||
| EFAIL | NRR | NRS | NRT | MRR | MSS | MTT | |
Definition
| mat_ID | Material identifier (Integer) |
| Initial density (Real) |
| E | Young’s modulus (Real) |
| v | Poisson’s ratio (Real) |
| SIGY | Yield stress (Real) |
| ET | Plastic hardening modulus (Real) |
| EFAIL | Plastic strain to failure (Real) |
| NRR | Axial failure force (for beam only, only ≥ 0).
EFAIL is ignored. (Real) |
| NRS | Shear failure force in local direction S (for beam only, only
≥ 0). EFAIL is ignored. (Real) |
| NRT | Shear failure force in local direction T (for beam only, only
| MRR | Torsional failure moment (for beam only, only ≥
0) (Real) |
| MRS | Bending failure moment along local direction S (for beam
only, only ≥ 0) (Real) |
| MRT | Bending failure moment along local direction T (for beam
- This keyword maps to /PROP/TYPE43 (CONNECT), /MAT/LAW59 (CONNECT) and /FAIL/CONNECT.
- This keyword linked to beam elements maps to /PROP/TYPE13 (SPR_BEAM).
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 character long line is added after the keyword input line which allows an entity title to be defined.
