*MAT_169 (ARUP_ADHESIVE)
LS-DYNA Input Interface KeywordThis keyword defines adhesive bonding material.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*MAT_169 or *MAT_ARUP_ADHESIVE | |||||||
mat_ID | E | v | TENMAX | GCTEN | SHRMAX | GCSHR | |
PWRT | PWRS |
Definition
mat_ID | Material identifier (Integer) |
Initial density (Real) |
E | Young’s modulus (Real) |
v | Poisson's coefficient (Real) |
TENMAX | Yield stress in tension (Real) |
GCTEN | Energy per unit area for bond to fail in
tension (Real) |
SHRMAX | Yield stress in shear (Real) |
GCSHR | Energy per unit area for bond to fail in
shear (Real) |
PWRT | Exponent value for failure in tension (Real) |
PWRS | Exponent value for failure in shear (Real) |
- This keyword maps to /MAT/LAW83, /FAIL/SNCONNECT, /PROP/TYPE43 (CONNECT).
- The material is fully compressible in the vertical direction from solid element face 1 to face 2.
- The tension stiffness is in the vertical direction and shear stiffness is perpendicular to the vertical direction.
- The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 character long line is added after the keyword input line which allows an entity title to be defined.
