/FAIL/SNCONNECT
Block Format Keyword Describes the failure model for CONNECTION material with plastic displacement criteria. This model allows a different failure behavior in normal and shear directions.
/FAIL/SNCONNECT/mat_ID/unit_ID
α 0 β 0 α f β f Ifail_so ISYM
fct_ID0N fct_ID0S fct_IDFN fct_IDFS XSCALE_0 XSCALE_F AREAscale
Optional Line
fail_ID
mat_ID Material identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
α 0 Parameter for the beginning of damage, due to moment loads. 2
(Real)
β 0 Exponent for the beginning of damage, due to combined shear and normal loads. 2
(Real)
α f Parameter for the final damage failure, due to moment loads. 2
(Real)
β f Exponent for the final damage failure, due to combined shear and normal loads. 2
(Real)
Ifail_so Solid failure flag.
= 1 (Default)
The solid element is deleted, when one integration point reaches the failure criteria.
= 2
The solid element is deleted, when all integration points reach the failure criteria.
(Integer)
ISYM Rupture deactivation flag for compression.
= 0 (Default)
Same behavior in tension and compression.
= 1
Deactivation of failure in case of compression.
(Integer)
fct_ID0N Function identifier defining a scale factor for displacement rate dependency in normal direction in initial yield function.
Default = 0 (Integer)
fct_ID0S Function identifier defining a scale factor for displacement rate dependency in tangential direction in initial yield function.
fct_IDFN Function identifier defining a scale factor for displacement rate dependency in normal direction in rupture yield function.
fct_IDFS Function identifier defining a scale factor for displacement rate dependency in tangential direction in rupture yield function.
XSCALE_0 Scale factor for the abscissa displacement rate for initial function.
Default = 1.0 (Real)
[ 1 s ]
XSCALE_F Scale factor for the abscissa displacement rate for rupture function.
[ 1 s ]
AREAscale Failure scale factor for area increase. 5
Default = 0.0, this option is not used (Real)
fail_ID Failure criteria identifier. 3
Example (Connect)
#RADIOSS STARTER
/UNIT/1
unit for mat
                  kg                  mm                  ms
#-  2. MATERIALS:
/MAT/LAW83/1/1
CONNECT MATERIAL
#              RHO_I
              7.8E-6
#                  E                         Imass
                  20                             0
#  Fct_ID1                      Y_scale1            X_scale1               ALPHA                BETA
       200                             1                   1                   0                   2
#                 RN                  RS   Fsmooth                Fcut
                  .2                  .4         0                   0
#  Fct_IDN   Fct_IDS              XSCALE
         0         0                   0
/FAIL/SNCONNECT/1/1
#            ALPHA_0              BETA_0             ALPHA_F              BETA_F  Ifail_so      ISYM
                   0                   2                   0                   2         1         1
#   Fct_0N    Fct_0S    Fct_FN    Fct_FS            XSCALE_0            XSCALE_F           AREAscale
      2001      2002      2003      2004                   1                   1                   0
#-  3. FUNCTIONS:
/FUNCT/200
MAT83 curve
#                  X                   Y
                   0                   1
                   1                   1
/FUNCT/2001
Fct_0N
#                  X                   Y
                   0                  .5
                   1                  .5
/FUNCT/2002
Fct_0S
#                  X                   Y
                   0                  .5
                   1                  .5
/FUNCT/2003
Fct_fN
#                  X                   Y
                   0                   1
                   1                   1
/FUNCT/2004
Fct_fS
#                  X                   Y
                   0                   1
                   1                   1
#ENDDATA
/END
  1. This failure model is compatible only with the connection materials, /MAT/LAW59 (CONNECT) and /MAT/LAW83. The connection materials are independent of height, so failure is based on displacement, instead of strain.
  2. A combined energy failure criteria is defined as:
    fail_snconnect
    Where, u ¯ n p l MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGabmyDayaara WaaSbaaSqaaiaad6gaaeqaaOWaaWbaaSqabeaacaWGWbGaamiBaaaa aaa@3A44@ and u ¯ s p l MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGabmyDayaara WaaSbaaSqaaiaadohaaeqaaOWaaWbaaSqabeaacaWGWbGaamiBaaaa aaa@3A49@ are the plastic displacement in the normal and tangential directions.
    Damage of element begins when the damage surface is reached which is described by:(1)
    1 = [ ( u ¯ 0 , n p l f 0 N ( 1 α 0 s y m ) ) β 0 + ( u ¯ 0 , s p l f 0 S ) β 0 ] 1 β 0 MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaGymaiabg2 da9maadmaabaWaaeWaaeaadaWcaaqaaiqadwhagaqeamaaDaaaleaa caaIWaGaaiilaiaad6gaaeaacaWGWbGaamiBaaaaaOqaaiGacAgada WgaaWcbaGaaGimaiaad6eaaeqaaOWaaeWaaeaacaaIXaGaeyOeI0Ia eqySde2aaSbaaSqaaiaaicdaaeqaaOGaeyyXICTaam4CaiaadMhaca WGTbaacaGLOaGaayzkaaaaaaGaayjkaiaawMcaamaaCaaaleqabaGa eqOSdi2aaSbaaWqaaiaaicdaaeqaaaaakiabgUcaRmaabmaabaWaaS aaaeaaceWG1bGbaebadaqhaaWcbaGaaGimaiaacYcacaWGZbaabaGa amiCaiaadYgaaaaakeaaciGGMbWaaSbaaSqaaiaaicdacaWGtbaabe aaaaaakiaawIcacaGLPaaadaahaaWcbeqaaiabek7aInaaBaaameaa caaIWaaabeaaaaaakiaawUfacaGLDbaadaahaaWcbeqaamaalaaaba GaaGymaaqaaiabek7aInaaBaaameaacaaIWaaabeaaaaaaaaaa@622D@
    Where, f 0 N and f 0 S are the function of fct_ID0N and fct_ID0S. If there are no rate effects, then the curves will be constant.
    The damage factor is computed as:(2)
    d = u ¯ p l u ¯ 0 p l u ¯ f p l u ¯ 0 p l MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamizaiabg2 da9maalaaabaGabmyDayaaraWaaWbaaSqabeaacaWGWbGaamiBaaaa kiabgkHiTiqadwhagaqeamaaDaaaleaacaaIWaaabaGaamiCaiaadY gaaaaakeaaceWG1bGbaebadaqhaaWcbaGaamOzaaqaaiaadchacaWG SbaaaOGaeyOeI0IabmyDayaaraWaa0baaSqaaiaaicdaaeaacaWGWb GaamiBaaaaaaaaaa@48E0@
    And the stress is reduced as:(3)
    σ = σ ( 1 d )
    The element is deleted when the rupture surface is reached:(4)
    1 = [ ( u ¯ f , n p l f F N ( 1 α f s y m ) ) β f + ( u ¯ f , s p l f F S ) β f ] 1 β f MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaGymaiabg2 da9maadmaabaWaaeWaaeaadaWcaaqaaiqadwhagaqeamaaDaaaleaa caWGMbGaaiilaiaad6gaaeaacaWGWbGaamiBaaaaaOqaaiGacAgada WgaaWcbaGaamOraiaad6eaaeqaaOWaaeWaaeaacaaIXaGaeyOeI0Ia eqySde2aaSbaaSqaaiaadAgaaeqaaOGaeyyXICTaam4CaiaadMhaca WGTbaacaGLOaGaayzkaaaaaaGaayjkaiaawMcaamaaCaaaleqabaGa eqOSdi2aaSbaaWqaaiaadAgaaeqaaaaakiabgUcaRmaabmaabaWaaS aaaeaaceWG1bGbaebadaqhaaWcbaGaamOzaiaacYcacaWGZbaabaGa amiCaiaadYgaaaaakeaaciGGMbWaaSbaaSqaaiaadAeacaWGtbaabe aaaaaakiaawIcacaGLPaaadaahaaWcbeqaaiabek7aInaaBaaameaa caWGMbaabeaaaaaakiaawUfacaGLDbaadaahaaWcbeqaamaalaaaba GaaGymaaqaaiabek7aInaaBaaameaacaWGMbaabeaaaaaaaaaa@6375@
    With, f F N and f F S being the function of fct_IDFN and fct_IDFS. If there are no rate effects, then the curves will be constant.
    • s y m = sin ( A ) MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4CaiaadM hacaWGTbGaeyypa0Jaci4CaiaacMgacaGGUbGaaiikaiaadgeacaGG Paaaaa@3EDB@ .
      Where, A MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8srps0lbbf9q8WrFfeuY=Hhbbf9v8 qqaqFr0xc9pk0xbba9q8WqFfea0=yr0RYxir=Jbba9q8aq0=yq=He9 q8qqQ8frFve9Fve9Ff0dmeaacaGacmGadaWaaiqacaabaiaafaaake aacaWGbbaaaa@399D@ is the angle between the normal of the lower surface and the normal of the upper surface of the solid element.
    • Parameters α 0 , α f MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqySde2aaS baaSqaaiaaicdaaeqaaOGaaiilaiabeg7aHnaaBaaaleaacaWGMbaa beaaaaa@3BEB@ are the scale factors used to describe the moment effect (for example, in a peeling test) for damage initiation and failure.
    • Parameters β 0 , β f MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqOSdi2aaS baaSqaaiaaicdaaeqaaOGaaiilaiabek7aInaaBaaaleaacaWGMbaa beaaaaa@3BEF@ are fitted using a test which combines normal and shear loards (30° test, 45° test or 60° test, etc.). At least one combined test is needed to fit the parameters β 0 , β f MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqOSdi2aaS baaSqaaiaaicdaaeqaaOGaaiilaiabek7aInaaBaaaleaacaWGMbaa beaaaaa@3BEF@ . Figure 3 and Figure 4 show the effect of β 0 , β f MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqOSdi2aaS baaSqaaiaaicdaaeqaaOGaaiilaiabek7aInaaBaaaleaacaWGMbaa beaaaaa@3BEF@ on damage initiation and failure in combined test.
      Figure 3. Elongation at Damage Initiation
      Figure 4. Elongation at Failure
  3. The fail_ID is used with /STATE/BRICK/FAIL and /INIBRI/FAIL. There is no default value. If the line is blank, no value will be output for failure model variables in the /INIBRI/FAIL (written in .sta file with /STATE/BRICK/FAIL option).
  4. With /ANIM/BRICK/VDAMi following damage variable value could be output in an animation file:
    VDAM1 = d is the damage value, which ranges from [0, 1].
    VDAM2 = the damage surface output, which ranges from [0, 1].
    VDAM3 = the rupture surface output, which ranges from [0, 1].
  5. The area is calculated as the mean value of the upper and lower surface of the solid element. If the actual area reaches the value of initial area multiplied by the AREAscale factor, the whole element will be deleted. The default value is set to zero. This causes no deletion, due to area increase. The application is to prevent shooting nodes, if the cohesive element nodes will be released, when surrounding elements start to fail and erode.
