/FAIL/GURSON
Block Format Keyword A Gurson-Nahshon-Hutchinson failure model describing the damage in terms of void nucleation and growth in metal plasticity.
The modified Gurson formulation adds additional damage accumulation terms for shear dominated loads, specific treatment under compressive loading, and elastic stiffness loss with damage.
/FAIL/GURSON/mat_ID/unit_ID | |||||||||
Iloc | |||||||||
As | Kw | ||||||||
Rlen | Hchi |
fail_ID |
Definition
mat_ID | Material identifier. (Integer, maximum 10 digits) |
unit_ID | Optional unit identifier. (Integer, maximum 10 digits) |
First Gurson damage coefficient. Default = 1.5 (Real) |
Second Gurson damage coefficient, maximum value =
1.02. Default = 1.0 (Real) |
Iloc | Damage variable accumulation method flag.
(Integer) |
Equivalent plastic strain at void
nucleation. (Real) |
As | Linear void nucleation slope. (Real) |
Kw | Shear damage growth coefficient. (Real) |
Critical void volume fraction at void
coalescence. (Real) |
Void volume fraction at ductile failure. (Real) |
Initial void volume fraction. (Real) |
Rlen | Radius of non-local variable influence
(Iloc >
1). (Real) |
Hchi | Non-local penalty parameter (Micromorphic method only,
Iloc =
2). (Real) |
fail_ID | (Optional) Failure criteria identifier. (Integer, maximum 10 digits) |
- The Gurson damage model
needs to be used with the elasto-plastic material
/MAT/LAW104. The yield surface definition of the
material law is modified by adding the damage evolution terms:
(1) Where,- ,
- Two Gurson-Tveergard-Needleman parameters.
- Effective damage
- Factor defined as:
- Total void volume fraction that is computed incrementally.
The kinetic equations of the damage factor increments are:- Void nucleation (creation of microcavities), decreasing at low
triaxiality.
(2) Where, is the stress triaxiality defined as:(3)
Figure 1. Nucleation of cavities - Void growth at high triaxiality:
(4)
Figure 2. Growth of cavities at high triaxiality - Additional shear void growth at low triaxiality which is shear
dominated:
(5) Where, is a weight function depending on the Lode angle:(6)
Figure 3. Growth of cavities at low triaxialityTo represent the cavities coalescence when a critical void volume fraction is reached by , the effective damage (which has an influence on the stress computation) is introduced in the model and its expression depends on :(7) Where, is the total void volume fraction at rupture for which .
Figure 4. Coalescence of cavitiesTo take into account the effect of the stiffness loss, a damage variable is computed as:(8) The effective damage is normalized by its rupture value which gives . The stress tensor is then computed as:(9) Where, is the elastic stiffness matrix.
The material fails when the cumulated total damage factor reaches the limit value . The element is then deleted.
- By default
, the damage variable is calculated step by
step using the local plastic strain values at each integration point.
However, one may want to use non-local regularization which offers mesh size
and the mesh orientation independent results (mesh convergence) for all
meshes using the mesh size
less than equal to the maximum value set by
the user
. This maximum mesh size
is then the highest mesh size used for which
results are mesh convergent. If one of the non-local formulations is used, , then the damage increments depend on a regularized nodal “non-local” plastic strain calculated on the entire mesh. The non-local plastic strain at nodes denoted is computed accounting for its own gradient and its local counterpart computed at the Gauss points following the set of equations below:
(10) The parameters and are automatically set. The user has to set the parameter Rlen which defines a non-local “internal length” which corresponds to a radius of influence in the non-local variable computation. This defines the size of the non-local regularization band (Figure 5).
Figure 5. Non-local regularization principleTo help choose a value for the parameter Rlen, one may follow the following expression:(11) - If
, the non-local Micromorphic method will be
used. For this specific method, another parameter is required,
Hchi. This parameter
and the non-local plastic strain
are introduced in the constitutive equation
as:
(12) Where, is the classical work-hardening function. This newly defined micromorphic work-hardening function Rchi is introduced in the flow stress computation . The parameter Hchi becomes a penalty parameter and if then and and so . This method is thermodynamically well defined. However, it is hard to identify the input values and it changes the plastic behavior of the model. This is why it is recommended to use the Peerlings method .
- If
, the non-local Peerlings method will be
used. For this method, the parameter
Hchi is used. Only
the non-local length Rlen
is used. This method is simpler than the Micromorphic one. It introduces the
non-local plastic strain in the softening variable kinetic equation (damage
and temperature if thermal effects are considered):
(13) (14) This method is recommended since it is simple to identify the input parameters and does not modify the plastic behavior of the material.
- When a non-local regularization is used for shell elements, an
additional regularization is made on the thickness variation computation
avoiding an additional localization issue. In the common local case (Figure 6), the compatibility of thickness
between shell elements is not ensured due to the lack of kinematic equations
in the z-direction, and the thickness variation is localy computed at Gauss
points. By introducing the non-local plastic strain in the “in-thickness”
strain increment, the compatibility is restored, (Figure 7).
(15) Where, is the non-local plastic multiplier.
Figure 6. Transverse strain incompatibility (local)
Figure 7. Transverse strain compatibility (non-local)Note: This last point implies that the identified parameters can be used on solid and shells, as results will be identical. - To create a specific damage output DAMA in ANIM and H3D files, the
total damage is normalized by its rupture value:
(16) - The model can only be used with material LAW104 for shell and solid elements.
