Load Cases
Block Format Keyword In Radioss the following load cases are available. Stress/strain as initial state could be considered by modeling, as well as pressure, gravity, and thermal load.
Also, different detonation/explosive loads can be defined with /DFS keywords. ALE, CFD and SPH condition (kinematic condition, pressure condition) are also available in this group.
