Obsolete
Block Format Keyword Keywords that are still supported, but no longer maintained (*) are considered obsolete.
(*) A keyword can become obsolete for several reasons:
  • Overtaken by a new and more powerful keyword (ex: FAIL/TAB1)
  • No longer used (ex: SHFRA/V4)
  • Dismissed (ex: MAT/LAW13)
Note: Obsolete keywords will continue to be supported, but they may no longer be exposed in upcoming versions of the manual. Also, new keyword are recommended, instead of obsolete keyword (except, /LEVSET).
Below is a list of Obsolete Starter keywords:
Obsolete Keywords/Features As of Version Replaced with New Keyword
/FAIL/TAB v13.0 /FAIL/TAB1
/FAIL/XFEM_FLD v13.0 /FAIL/FLD with Ixfem = 1
/FAIL/XFEM_JOHNSON v13.0 /FAIL/JOHNSON with Ixfem = 1
/FAIL/XFEM_TBUTCHER v13.0 /FAIL/TBUTCHER with Ixfem = 1
/INTTHICK/V5 v13.0
/LEVSET v13.0 /INICRACK
/MAT/LAW13 (RIGID) v13.0
/MONVOL/AIRBAG v13.0 /MONVOL/AIRBAG1
/MONVOL/COMMU v13.0 /MONVOL/COMMU1
/MONVOL/FVMBAG v13.0 /MONVOL/FVMBAG1
/PROP/TYPE5 (RIVET) v13.0
/RIVET v13.0
/SHFRA/V4 v13.0
/ALE/DISP v14.0.220 /ALE/GRID/DISP
/ALE/DONEA v14.0.220 /ALE/GRID/DONEA
/ALE/SPRING v14.0.220 /ALE/GRID/SPRING
/ALE/STANDARD v14.0.220 /ALE/GRID/STANDARD
/ALE/ZERO v14.0.220
/PERTURB v2017.2 /PERTURB/PART/SHELL
Modif Input File v2018
/INTER/TYPE20 v2018 /INTER/TYPE24
/MAT/LAW51Iform=3 v2018 /MAT/LAW51 Iform = 6
/UPWIND v2018 /ALE/MUSCL
/PROP/TYPE14 Isolid=12 v2018 /PROP/TYPE14 Isolid=17
/CAA v2020 /ALE/SOLVER/FINT - Iform=2
