/FAIL/XFEM_FLD (Obsolete)
Block Format Keyword Describes a XFEM (eXtended Finite Element Method) failure model.
/FAIL/XFEM_FLD/mat_ID/unit_ID
fct_ID Ifail_sh
Optional Line
fail_ID
mat_ID Material identifier
(Integer, maximum 10 digits)
unit_ID Unit Identifier
fct_ID Function identifier
(Integer)
Ifail_sh Shell failure flag
= 1
Shell is cracked (not deleted), if there is one layer in failure zone.
= 2
The layer tensor stress is set to zero if this layer is in the failure zone, and shell is cracked (not deleted), if all layers are in the failure zone.
(Integer)
fail_ID (Optional) Failure criteria identifier 2
  1. This failure model is available for Shell only.
    fail_fld
  2. The fail_ID is used with /STATE/BRICK/FAIL and /INIBRI/FAIL. There is no default value. If the line is blank, no value will be output for failure model variables in the /INIBRI/FAIL (written in .sta file with /STATE/BRICK/FAIL option).
