/INIBRI/FAIL
Block Format Keyword Describes the failure criteria for a brick.
/INIBRI/FAIL/unit_ID | |||||||||
brick_ID | Nlay | nptr | npts | nptt | lay_ID | fail_ID | Ifail_typ | Nvar | mat_ID |
V1 | etc | etc | VN |
unit_ID | Unit Identifier (Integer, maximum 10 digits) |
brick_ID | Element
identifier (Integer) |
Nlay | Number of
layers (Integer) |
nptr | Number of integration
points in direction r (Integer) |
npts | Number of integration
points in direction s (Integer) |
nptt | Number of integration
points in direction t (Integer) |
lay_ID | Layer to initialize
fail_ID | Failure criteria to
initialize identifier (Integer) |
Ifail_typ | Failure criteria to
initialize type. 5 (Integer) |
Nvar | Number of failure criteria
variables to initialize. (Integer) |
mat_ID | Material identifier to
V1 | First failure criteria
variable value. (Integer) |
VN | Nth
failure criteria variable value. (Integer) |
Example (One Failure Model)
/MAT/PLAS_JOHNS/1/1
Steel
# RHO_I
7.8E-9 0
# E Nu
210000 .3
# a b n EPS_p_max SIG_max0
270 450 .6 0 0
# c EPS_DOT_0 ICC Fsmooth F_cut Chard
0 0 0 0 0 0
# m T_melt rhoC_p T_r
0 0 0 0
/FAIL/JOHNSON/1/1
# D1 D2 D3 D4 D5
0.11 0.08 -1.5 0 0
# EPS_0 Ifail_sh Ifail_so Dadv Ixfem
1 1 1 0 0
# Fail_ID
4711
/PROP/SOLID/1/2
Solid part -1
# Isolid Ismstr Icpre Inpts Irot Iframe dn
14 0 0 0 0 0 0
# q_a q_b h
0 0 0
# dt_min
0
Output state file (*.sta)
#---1----|----2----|----3----|----4----|----5----|----6----|----7----|----8----|----9----|----10---|
/INIBRI/FAIL
#------------------------ REPEAT --------------------------
# BRICKID NLAY NPTR NPTS NPTT ILAY IRUPT IRUPT_TYP NUVAR IMAT
# REPEAT K=1,NPTR,NPTS
# UVAR(1,I) .............
# ............... UVAR(NUVAR,I)
#---------------------- END REPEAT ------------------------
1 1 2 2 2 1 4711 1 1 1
9.8766841568993E-01
9.8766841568993E-01
9.8766841568993E-01
9.8766841568993E-01
9.8766841568993E-01
9.8766841568993E-01
9.8766841568993E-01
9.8766841568993E-01
Example (Two Failure Models Applied on One Material)
/MAT/PLAS_JOHNS/1/1
Steel
# RHO_I
7.8E-9 0
# E Nu
210000 .3
270 450 .6 0 0
0 0 0 0 0 0
0 0 0 0
/FAIL/JOHNSON/1/1
# D1 D2 D3 D4 D5
0.11 0.08 -1.5 0 0
1 1 1 0 0
# Fail_ID
4711
/FAIL/BIQUAD/1/1
# SAHRAEI1 BIQUAD
# c1 c2 c3 c4 c5
0. 0.0 0.3 0.00 0.0
# P_thickfail M-flag
.0 1
# Fail_ID
5711
/PROP/SOLID/1/2
Solid part -1
14 0 0 0 0 0 0
# q_a q_b h
0 0 0
# dt_min
0
/INIBRI/FAIL
9.8766841568993E-01
9.8766841568993E-01
9.8766841568993E-01
9.8766841568993E-01
9.8766841568993E-01
9.8766841568993E-01
9.8766841568993E-01
9.8766841568993E-01
1 1 2 2 2 1 5711 30 3 1
2.4163849709251E-01 0.0000000000000E+00 0.0000000000000E+00
- If nptr > 1, npts > 1, nptt > 1, the lines with real values have to be repeated for each integration point.
- Nvar values needs to be written for each integration point of the elements as a block of Nvar variable Vi with 3 variables per line.
- The total number of integration in the element is: .
- The integration points are
order from nptr, npts and
nptt.
Example for 4 integration points in (r,s,t): (1,1,1), (1,1,2), (1,2,1), (1,2,2), (2,1,1), (2,1,2), (2,2,1), (2,2,2).
- Every
failure model has a Ifail_typ which is used to identify the
failure model to initialize for the element. Verify failure law to element type
compatibility in /FAIL.
- Keyword
- Ifail_typ
- /FAIL/BIQUAD
- 30
- /FAIL/CHANG
- 13
- /FAIL/CONNECT
- 20
- /FAIL/EMC
- 27
- /FAIL/ENERGY
- 11
- /FAIL/FABRIC
- 31
- /FAIL/FLD
- 7
- /FAIL/HASHIN
- 14
- /FAIL/HC_DSSE
- 32
- /FAIL/JOHNSON
- 1
- /FAIL/LAD_DAMA
- 18
- /FAIL/NXT
- 25
- /FAIL/ORTHSTRAIN
- 24
- /FAIL/PUCK
- 16
- /FAIL/SNCONNECT
- 26
- /FAIL/SPALLING
- 8
- /FAIL/TAB1
- 23
- /FAIL/TBUTCHER
- 2
- /FAIL/TENSSTRAIN
- 10
- /FAIL/USERi
- 4, 5, 6
- /FAIL/WIERZBICKI
- 9
- /FAIL/WILKINS
- 3
